Help, Help, Help
BigMike005
Miami, FL
Haven't posted on here for some time now...
I have a 05 1500 5.7, My ******** washed the engine, now it wont start...Replaced starter nothing. replaced cam and crank sensors nothing, also changed out the ignition switch..its been three days and still nothing... starter wants to turn but dosnt... Battery is 100% aok
Any ideas my fellow Ram Forumers!!!
bhonshell37
Washington
Have you made sure each ignition coil is dry
B
BigMike005
Miami, FL
I've bypassed the ignition switch and feed power straight to the starter, she cranks and runs. But won't crank with the key..starter wants to initiate the crank but then stops... I have no clue?!
BBRAM2500
stony plain Alberta
Sounds like a bad relay or a wet one so to be clear if you bypass the starter it will crank and run but the ignition wont crank it over?
B
BigMike005
Miami, FL
Yes it cranks over if I feed straight power...I've been up and down the relays they all seem dry top and bottom..
B
BigMike005
Miami, FL
I'm thinking it might be my solenoid pack in the tranny...my PRND21 are all in squares...
BBRAM2500
stony plain Alberta
Id be looking for water in a harness then causing a short sounds like the neutral saftey switch is open then
B
BigMike005
Miami, FL
All fixed!!! Dumb engine ground had water in it!! Replaced it cranks over every time!! Thanks for ur help!!!!
lasse452
