tosch
Hi!
I've got a Hemi 04 2WD and if I turn the key lights from ABS, Brake and so one light up in the speedometer. All the gauges rest behind zero and if I try to start nothing happens, no noise no click.
What I've done so far:
new battery
new ignition switch
changed ECU
changed Fuse box
bridged relais No.57 gauges came on and I was able to turn over, but engine didn't fire up. the volt gauge came on very slow about 3-5 secs.
Anyone got an idea?
Greetings, Torsten
new battery
new ignition switch
changed ECU
changed Fuse box
Anyone got an idea?
Greetings, Torsten
