I know I have probably asked this before but...
truckin151
2013 sport
How hard would you think swapping to a 4th gen coil over suspension would be? If I could get a hold of all the brackets and mounting equipment for the axle and get a hold of all the parts, about how hard do you guys think it be? Is the frame on the 4th gens the same as close to the same as the 3rd gens?
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
I don't have one of each in the shop right now to compare the two but I can't imagine it being worth the effort, personally. I prefer the height adjustability of torsion bars because you can get a better alignment.
RubberFrog
Are you talking front or rear? The 4th gen front end is the same as the 3rd gen. So the front swap would be relatively easy, although not a bolt on. The back end I can't say.
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
If we're talking a 4x4 then the difference is torsion bars versus the coils.
RubberFrog
Yeah, I guess I always have 4x4 on my mind. I believe truckin is a 2wd.
T
truckin151
2013 sport
2wd, front should be the same, looking more for the rear setup
HemiBabe
DFW
That would be awesome to do!
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
Oh ok. 2wd's sit so high these days it's hard to tell from a pic. You're wanting to convert from leafs to coils?
RubberFrog
Gotta love the leafs on a 2wd. Too stiff for daily driving, too soft for hauling. It's like they designed them to purposely meet the worst of both worlds.
HemiBabe
DFW
You got that right, George. My truck's ride is so crappy
It would be awesome to have the coils
RamTech
Johnson City, TN.
2004 Dakota SXT
3.7L
If it's too stiff, why not pull a leaf out? I did it with a truck I had years ago to lower it and the improvement in the ride was perfect.
RubberFrog
That doesn't really fix the handling issue back there. It does soften the ride though.
T
truckin151
2013 sport
Pull a leaf and you lose the use of actually using the bed of the truck which I do use every now and then. YOu can add in helper bags but again that doesnt help the handling or ride.
The coil over setup with their 5 link (?) gives a much better ride quality in traction, handling and over all smoothness of the ride itself without losing the ability to load the truck up and use it as a truck when those 2 days out of the year come up.
pavester
texas
for the money spent on converting it you could probably be fairly close to having a full procharger setup on the truck....;)
T
truckin151
2013 sport
And still be bouncing all around on the road... Handling and ride quality are just as important as making a lot of hp and tq.
As long as the frames are the same, it shouldnt be to expensive to work out.
RubberFrog
Find a wrecked 4th gen and bring your cutting torch
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Wonder how much it would be to do a one off 4 link???? Bet some of the lowered guys will know of such.
T
truckin151
2013 sport
Thought about it but everything I have read and everyone I have asked said doing a one off 4 link is not worth the time or effort. But if the 4th gens setup is a fairly simple conversion (as long as the frame is the same and just need some mounts) then it should be pretty straight forward I would think/hope
Hemiguy0302
Edmonton Alberta Canada
6.2 Boss
I'm sure your best route would be to run a linked rear setup on bags that is designed for the 3rd gen trucks. Air up to haul a load air down to haul ass with good weight transfer at the track.
