Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
i need help badly.
This is a discussion on i need help badly. within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
I developed an exhaust leak where my Stock Y pipe meets my catalytic converter. Dealer tells me that the only ...
Sponsored By: Moe's Performance
Reply
Old 09-06-2012, 08:50 PM   #1 (permalink)
02blkram47's Avatar
Ram Year: 2011 Longhorn Crew Cab
Engine: 5.7 Hemi
Default i need help badly.
I developed an exhaust leak where my Stock Y pipe meets my catalytic converter. Dealer tells me that the only way to get this Y pipe from Chrysler is to get the entire section that contains the cat which costs nearly $700. So my question is this
1. Can I just buy an aftermarket Y pipe like magnaflow and get this to fit with my cat?
2. Do I need to buy a new cat back system and cat with new Y pipe?
I was told that if I didn't want to pay for the stock Y and cat the dealer had a "guy" who would build me a new pipe with flange to connect to my cat for $440. That sounds crazy expensive to me.
I'm looking for the most simple solution? Any thoughts
I'm thinking about either an summit racing system or the American thunder system but what do I do with the cat and a leaky Y pipe?
Sponsored Ad
Register to remove this ad.
__________________
Current mods: CIA / PRO COMP 17" WHEELS / BILSTEIN HD / GO RHINO EXTREME 6" STEPS / NIFTY EXTREME CATCH ALL FLOOR MATS / LED TAILS /FLOWMASTER DUMPED / Power Stop drilled & slotted rotors / Ceramic pads
Future mods: double din / leather seats / projector headlights
02blkram47 is offline   Reply With Quote
Old 09-06-2012, 08:54 PM   #2 (permalink)
Hemi450hp's Avatar
Ram Year: 2011 Ram 1500
Engine: 5.7L Hemi
Default
You would be fine by just replacing the Y-pipe with a new Magnaflow. Adding a catback exhaust after that is going to make it sound great and add some power, but not necessary to get the leak fixed.
Do you know what size piping you have before and after the Y?
__________________
2011 Ram 1500 - 11.99 @ 110.66MPH N/A
2011 Ram 1500 - 11.09 @ 120.13MPH Nitrous
2014 Ram 1500 - 12.38 @ 109.61MPH N/A
Hemi450hp is offline   Reply With Quote
Old 09-06-2012, 08:56 PM   #3 (permalink)
05singlecabHEMI's Avatar
Ram Year: 2005
Engine: 5.7 HEMI
Send a message via Yahoo to 05singlecabHEMI
Default
Go to an exhaust shop and have him cut out like 1foot of pipe and have him put in a new peice. Id bet no more then $100
__________________
55W Bixenon Digital HIDs, Retro shop projectors with halos, LED Switchback turns, Pacesetter LT headers dual exhaust flow master 40series dumped before the axle, raceland 3" cutoutvararam air intake, 1.5inch leveling kit, Dakota AT^2 tires, plastidipped wheels, DSP 93octane tune, rocket wire, aeroforce gauge in a SRT 10 pillar with A/F ratio, color matched gill, plasti dipped bumpers. Sonnex Line Booster, Bedrug, Extang bed cover, ground force drop shackles. 85MM throttle body.
05singlecabHEMI is offline   Reply With Quote
Old 09-06-2012, 09:02 PM   #4 (permalink)
02blkram47's Avatar
Engine: 5.7 Hemi
Default
So I have a flowmaster muffler with a turn down pipe. I put the turn down on myself and that was 2 5/8 so I'm assuming the muffler was a 2.5" outlet. I have no idea what is before the muffler but I do know its stock piping for a 4.7 L motor.
So any Y pipe will connect up to the cat? If that's the case I'd be happy to buy a new cat back and the Y pipe. So would this be 2.5" pipe all the way front to back?
__________________
Old 09-07-2012, 10:29 AM   #5 (permalink)
KGBIGCOUNTRY's Avatar
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
It is leaking right at where the pipe meets the cat? Any exhaust shop should be able to get you fixed up regaurdless
__________________
[CENTER]
Got Lope? WANNA GO FAST?
Hit us up at Moe's Performance for all your needs
http://www.moes-performance.com/
KGBIGCOUNTRY is offline   Reply With Quote
Old 09-07-2012, 11:06 AM   #6 (permalink)
02blkram47's Avatar
Engine: 5.7 Hemi
Default
I haven't crawled under there yet to see myself but the dealer said it was right where they meet. I think I have decided to buy an new Cat back system and get the Y pipe as well and just have an exhaust shop put it up and weld it all. Should be between $300-$350 total i would guess.
__________________
Old 09-07-2012, 11:29 AM   #7 (permalink)
Ram Year: 2002 QCSB 4X4
Engine: supercharged 5.9
Default
is your cat made right into the y like mine was? they are very expensive. if so, i would just redue the exhaust. new y pipe, new high flow cat, and pipe to connect the rest. like stated above, good exhaust shop could fix you right up. probabably cheaper with better performance.
__________________
comp cam,2.02 heads,2600 stall,pacesetter lt's,52mm fastman,fastman simm,sct,perma-cool efans,hs 1.7 rockers,hughes airgap,aem wideband,aem boost,aem trans,innovate lm2,msd coil,msd superconductors,msd streetfire ign,magnaflow,vortech s/c 8lbs,walboro 255pump,39lb inj.,intercooler.nitrous express.
talon6 is offline   Reply With Quote
Old 09-07-2012, 11:32 AM   #8 (permalink)
Default
heck, if its not that bad, they might even be able to just weld your old y up and fix it.
__________________
Old 09-07-2012, 04:31 PM   #9 (permalink)
02blkram47's Avatar
Engine: 5.7 Hemi
Default
Yes my Y is part of cat which is why they are like $700 from Chrysler. So now I'm wondering if I need a new Cat or can I just buy the Y along with a Cat back system? Only reason I'm asking is because now I have to replace my rear axle seal, left front cv axle, and the rack & pinion on top of needing a new exhaust system. I have never seen so many things go wrong at one time. All of this started because I hear a grinding noise when I take a right turn mostly when going up hill. They think it's the CV axle that has play in it ( I'm not convinced) the boot is still good no cracks or rips and I can turn just fine with no sloppiness. I'm thinking more to do with the rear seal maybe it's out of fluid completely or it part of bigger problem like a wheel bearing. I have no idea but I'm trying to figure out what to replace first and make it as cheap as possible. sorry for the rant
__________________
Old 09-07-2012, 04:43 PM   #10 (permalink)
truckin151's Avatar
Ram Year: 2013 sport
Engine: 5.7
Default
The Magnaflow Y pipe doesnt replace that entire piece, only where they combine to creat the Y shape. But really, unless you cat is bad, just take it to any exhaust shop and have them run a new bead where the pipe meets the cat. If it costs more than $50 for the weld I'd be shocked
__________________
2013 RAM 1500 SPORT - Let the modding begin.... Again
truckin151 is offline   Reply With Quote
Reply
Tags
dodge ram y, ram y pipe, replacement y pipe
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
