Redtruck-VA
- Jun 29, 2010
- 5,864
- 984
- Virginia
- 2003 & 1989 D250 RWD
- Hemi-5.7, 5.9 12v & 24v diesel
Ok guys, I got too much time on my hands. Give me your thoughts about this setup. This would obviously work best on a stroker motor, but might provide some gains on a slightly worked motor as well. I especially like the manifold on a boost engine as the manifold is being pressurized and you could easily do a little maching and turn this into one hell of a nitrious rig with port injection.
My initial thought is to use a ported TB and bolt it to an adapter plate and mount it pointing up. This would be straight foreward and no doubt would work. A second thought is to modify a billet TB using the FBW assembly off of a old OEM TB. There is plenty of aftermarket 4 barrel TB's, but they are setup to run on GM's or cable. Hell, maybe use the TB off of a Viper if it is FBW. Anyway just having a couple cool ones and thinking out loud.
