I just installed a K&N intake system on my 2006. All went well and she fired right up. I back it out of the garage and was letting it idle while I was cleaning up. When I went to take the truck for a ride it was dead, every warning light was on and the truck would not turn over, NOTHING. It turned out to be the PCM fuse. I replaced that and all was good with thing the world, so I thought. I checked the codes, and there were no codes stored. Test ride when well and the intake made the truck sound like a beast. After I was home for a while I decided to go back out and let it idle and see if it would act up again. After about 20 mins the "Check Gauges" Light came on. I shut the truck off and started it back up and it was out, but it shortly came back on. All the gauges were reading normal, the idle tack seemed to be jumping around a tad while the idle did not seem to change. Truck was running fine and was i went for a ride and it was running great but the light was still on. I am baffled by this one, any advice would be greatly appreciated.
