You need the '06-'08 valve covers and ignition coils, then you can either cut and wire in the new coil plugs to your existing harness or pick up an adapter set.
So the bolts on the valve cover are on the opposite location of the ones that are on there now. The question is, does it have to be ram valve covers/coil packs or will the car version work?
