cadamwiggins
- Oct 17, 2016
- 1
- 0
- 2005 ram 1500
- 4.7
Long time lurker, first time poster. If this topic is already being discussed elsewhere please move it to the appropriate thread. I have a 2005 ram 1500 with the 4.7l engine. Recently I have developed an issue with a low oil pressure warning. Only when the engine has warmed to operating temperature and only when coming to a stop. As soon as I stop my RPM's drop almost as if it is going to stall at the same time the warning for low oil pressure starts to go off if i press on the gas pedal the warning stops. I replaced the oil pressure sending unit but the problem hasn't been resolved. Someone told me it could be that the screen on the pickup tube could be clogged. I was also told there was an issue with the pickup tube not being wide enough and that it clogs quite easily and that replacements tubes have been made to remedy that.
So my questions are:
1. What are the most likely culprits for this issue?
2. Would it be best to start by pulling the pan and inspecting the tube and screen or is this issue more serious? If the screen is clogged is it easy to clean or should it be replaced
3. Is there any truth to there being an issue with the width of the pickup tube?
