More questions i should already know the answer to
Gecko
NJ
5.7L Hemi, 8.3L V10
Unfortunately, unless you plan on drilling into your valve cover, you won't be able to install one on your truck. The 3rd gens have an internal PCV that makes using a catch can almost impossible.
StaLL1oN
Arkansas
2003 1500 Quad cab SLT 4x4
Gecko thought you were running a catch?
Gecko
NJ
5.7L Hemi, 8.3L V10
Nah no catch can.
Though I've been talking with my buddy and said we could just drill each valve cover and run a breather filter from each and that would help. So that may happen in the future.
StaLL1oN
Arkansas
Nah no catch can.
Right on good idea
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Catch Can on a 3g... this is how I did mine. I modified the PCV to vent straight to the crank case eliminating the PCV function. The vent hose then goes to the catch can. From the oil fill tube which also vents to the crank case goes also to the Catch can. And finally the vent hose to the intake tube provides progressively more draw as rpm increases.
