Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Need advice/help with spark plug job.
This is a discussion on Need advice/help with spark plug job. within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
2008 1500 4.7. So, even after reading all the horror stories, I decided I would try to tackle the top ...
Sponsored By: Moe's Performance
Reply
Old 12-06-2016, 04:26 PM   #1 (permalink)
Ram Year: 2008
Engine: 4.7
Default Need advice/help with spark plug job.
2008 1500 4.7.
So, even after reading all the horror stories, I decided I would try to tackle the top plugs on my 4.7. My truck only has 44500 miles (I don't drive it much), but is 9 years old. I'm the original owner, and the plugs are all original. I ordered 8 Bosch replacement plugs, and decided I would give it a go today.
I started with the first plug on the driver's side. The coil pack popped right off with no issues (that was a relief). Next, I inserted my thin walled 5/8" plug socket and began to back the plug out. It was very, very stiff. I made it about 2 full turns before I stopped. I've snapped off plenty of bolts before, and this is exactly what it felt like. I used some penetrating oil, and gave it a good squirt, then let it sit for a couple of hours.
I came back out and tried again. And again, it was very stiff. I went half turn out, half turn in, half turn out, etc. I was making progress, but it really felt like it was stripping threads, or about to break, and I was only about half way out. At this point, I took a step back. I decided to try the second plug, to see if it was the same. I pulled the second coil pack and the boot was 100% orange. It was covered with rust powder. I looked down in the plug hole, and the plug was completely orange with rust. Grrrrrrrrr.
I decided to put everything back and pray that I didn't do any damage. I put the second coil back and buttoned it up. Next I went back to plug number 1. I started tightening it back down, and it was equally as hard. By tightening, loosening, tightening, loosening, etc, I was able to get it fully seated, or so I think. I put the air hat back on, and the intake hose, and buttoned everything back up. Cranked her up, and she started as normal. I did not notice anything out of the ordinary.
So here's the dilemma:
A. Should I try again, when I have more time and patience, and lots of penetrating oil?
B. Should I forget about the plugs, and just drive the truck as is? It runs great, and I only put about 5000 miles on it per year, and will probably keep it for another 4-10 years.
C. Should I take it to the dealer and pay them to change the plugs?
D. Other ideas?
Sponsored Ad
Register to remove this ad.
lharrell79 is online now   Reply With Quote
Old 01-07-2017, 04:30 AM   #2 (permalink)
Ram Year: 2005
Engine: 4.7 Magnum
Default
A - I'd get everything I could out of those holes with compressed air, soak them with PB Blaster, and let it sit overnight. Next morning try to take them off with the engine cold, if that doesn't work, try it warm (wouldn't hurt to try, right?).
B - Depends on how much you want to spend. Proper maintenance will save you money down the road (speaking from experience).
C - Having a mechanic replace the plugs is going to be cheaper than new heads.
Have fun with the coil on #8.
Blue_Smoke13 is offline   Reply With Quote
Old 01-08-2017, 11:21 PM   #3 (permalink)
Burla's Avatar
Ram Year: 2010 Hemi Reg Cab 4x4
Engine: Hemi
Default
There is a big difference between 4 or 9 years. If it is 4, let it go. If it is more like nine, pay the 800 for new plug job. In fact, if you put in the effort and money, you will be more likely to keep it longer, always the smart play. Buying new vehicles sucks. I'd get mopar plugs.
Use this stuff, the reason why it probably is so hard to remove is the factory didn't put it on. I try and change my plugs the first 20k miles. Take the hard ones out with the engine hot.
Here.
Burla is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Spark plug help!!! Plug stuck in Head PCT Engine & Performance 48 04-11-2016 07:32 PM
Did spark plug change and one old plug looks terrible Ccravillion Engine & Performance 4 09-19-2015 10:04 PM
Spark plug wire advice StaLL1oN Engine & Performance 11 03-01-2015 09:24 PM
spark plug gap? 620mac Engine & Performance 6 01-29-2015 08:34 AM
One more Spark Plug ? etmsdadkm Engine & Performance 5 07-22-2013 11:38 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
