Need stopping power
Immortaldaul
San antonio tx
5.9 magnum
Hey guys I have a stock dodge ram 1500 with the 5.9 magnum. I wanted to know if it's possible to upgrade my brakes to ram 2500 brakes? If so not what should I do for you increased stopping power? 027bc862447c003607c734ce307f18fa.jpg
Sent from my LG-E980 using Tapatalk
charonblk07
Calgary, Ab
F1-A forged 349ci
Your best and cheapest option for a significant upgrade is to do a hydroboost conversion unless you want to run a big brake kit. None of the 2500 suspension will transfer over since it's a SFA. The hydroboost conversion from the diesel is a HUGE increase in stopping power and it gets rid of the vacuum booster you currently have. I did a write up for installing it in a 4th gen but it's the same for the 3rd gens as well, you'd just be tapping into the power steering pump in a different location than on the 5.7L. Weedahoe also has a youtube video on a 3rd gen.
http://www.ramforum.com/f75/how_4th_gen_hydrobooster-71025/
Immortaldaul
Immortaldaul
San antonio tx
5.9 magnum
Yeah I think I'd prefer the big brake kit. Any suggestions? The truck has maybe a good three year before I start looking for a new one
charonblk07
Calgary, Ab
F1-A forged 349ci
The SSBC tri-power kit will bolt in but it's $1400 and that's the cheap one; Baer is $4k, Rotora is $7k. Keep in mind that each has a progressively larger minimum wheel diameter.
usaf2006
Augusta, GA
What do you need more stopping power for? Lots of high speed chases?
Immortaldaul
Immortaldaul
San antonio tx
5.9 magnum
Figured if I was gonna change my brake pads and what not might as well find out if there were any worthwhile upgrades I could do as well.
Immortaldaul
Immortaldaul
San antonio tx
5.9 magnum
Meh I guess I won't worry about it. Figured it would be worth asking. Guess I'll juts go with ceramic pads or something
charonblk07
Calgary, Ab
F1-A forged 349ci
The hydroboost conversion costs about $300 in parts and is a huge increase in stopping power over the vacuum booster.
Immortaldaul
Immortaldaul
San antonio tx
5.9 magnum
I'll have to think abut that.
