Ok, need some advice. Was driving home Sunday on Hwy. Kept getting some rpm fluctuations around 2200. I slowed down and took out of OD. Truck ran perfect. 10 minutes later I put OD back on and it was fine. Stopped for gas. Went to pull onto road and rpms just revved up, no drive. Let off gas and engine died. Switched to neutral and engine started right back up. Put in drive and it started going. About half mile later, did the same thing. Started right back up, but this time I had no drive. Pulled off the road and stopped. Ran through all gears and I have nothing. Switch to 4wd and nothing.
It just revs like it is in neutral. Never made any noises. When I shift between reverse and drive, it sounds like it is changing gears, but no movement.
Towed it home. Checked codes and only one was the P0740 code, for TCC lockup. That code has been there for last 65k miles. Drained fluid and it was perfect. No discoloration, no smell of burnt fluid in both tranny and transfer case. Dropped pan and there is no metal and just normal amount of clutch sludge on magnet.
Had anyone seen this before? Is tranny toast or is this another problem? Can't afford a new transmission, so my only option is a used one. Just wanted to get opinions before pulling the transmission.
Thanks in advance!
Thanks in advance!
