No oil pressure cold start
1209er
HEMI 5.7
I m not getting oil pressure when i turn my truck on from a cold start or when its been off for a couple hours. When this happens i just turn it off then turn it back on and the pressure is fine what could be causing this.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Could be normal wear and tear, it takes cold oil a second to get up top and get decent pressure.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
The sensor port is within a couple inches of the pump and should see pressure almost immediately.
I lost oil pressure not long ago and pulled the sensor to see if I had any real pressure and didn't have any. I replaced the oil pump and thoroughly inspected the pickup tube. Installed a o ring and a small mechanical gauge at the sensor port. Fired up and all is good, getting 65psi.
I would first check the sensor.
1209er
HEMI 5.7
Im going to have to look into that. My neighbor said it could be a bad sending unit hes a mechanic but he only works on old cars pre efi would that cause the loss of oil pressure
Redtruck-VA
Virginia
A faulty sensor I would say is the most common cause. What we have is not what you think we have and that is a gauge. What we have is a indicator that looks like a gauge. If the pressure is more than 5psi the gauge reads in the middle, when less than 5 psi it reads zero and sounds a ding and throws a code. It is nothing more than an idiot light that looks like a gauge.
1209er
HEMI 5.7
So would the sensor be the first thing i should look into?
hotkarl
4.7 Semi-Hemi
The oil pressure senders on these trucks suck. Big time.
1209er
HEMI 5.7
Can u send me a link to the part i cannot find its an 2004 5.7 it would be extremely helpfull
Redtruck-VA
Virginia
It's located on the left front of the engine on the passenger side. Look at the picture I posted. The gauge is Tee'd to the sensor.
1209er
HEMI 5.7
Should have worded that better i meant were to purchase it a link to the item sorry about the mix up and thanks for all the help.
Redtruck-VA
Virginia
I would think any local parts store will have one. Dealer if you can't find one.
1209er
HEMI 5.7
Sounds good thanks for all the info.
