Hey all, Here is my problem. 2004 Dodge Ram 1500 5.7 HEMI... No power to the fuel pump.
Fuel pump is new, tested and is good. Relays have been tested and are fine, they also click when key is turned on. Fuse is good as well. New crank sensor. Ground at tank has been checked and ruled out. Continuity test if power wire from fuse box to plug at pump check out good. Replace relay with jumper wire (paperclip) truck runs like new with 58-60 psi on the rail. I am at a loss of what else it may be. HELP please!
