Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Oil pan gasket on 5.7
This is a discussion on Oil pan gasket on 5.7 within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
Hey guys. I've got a 2004 5.7l 4wd, and I've got what I believe to be an oil leak coming ...
Like Tree2Likes
  • 2 Post By Core-Lokt
Sponsored By: Moe's Performance
Reply
Old 01-11-2017, 11:35 PM   #1 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default Oil pan gasket on 5.7
Hey guys. I've got a 2004 5.7l 4wd, and I've got what I believe to be an oil leak coming from the oil pan gasket. Oil pan is in good shape. My question is, is it possible to replace the oil pan gasket without fully removing the pan? As I see that the latter option involves lifting the engine or dropping the pumpkin...
Sponsored Ad
Register to remove this ad.
Jersey ram is offline   Reply With Quote
Old 01-12-2017, 07:44 AM   #2 (permalink)
Core-Lokt's Avatar
Ram Year: 2005 Ram 2500 4X4 ST
Engine: 5.7L
Default
I replaced my timing chain assembly and oil pump in November, so it's pretty fresh in my mind. That said, my truck is a 3/4-ton and if yours is a 1/2-ton, not everything is possibly applicable.
There isn't so much a gasket as there is a windage tray with molded gasket. The oil pick-up tube runs through the windage tray and is fastened to an extended #3 main bearing cap stud on the bottom (sump side) of the tray.
The trick is to get the new windage tray between the pan and block and slip the pickup tube bell through that windage tray opening and get that #3 stud fastener attached. But I did it alone and on my back, so it can be done at home. Either allow ample time or get a helper; just having one end of the pan supported while you shuffle things around would help.
I read that the corners of the pan where (at least) the timing cover attach to the pan/windage tray are supposed to have a sealer bead. I got a Fel-Pro windage tray and it came with a small tube of black Permatex. IDK if that's included with all trays or if a subsequent spec revision doesn't call for it. I did make a small bead all the way around the top of the tray. Good luck.
Jersey ram and RonJon '06 like this.
__________________
Core-Lokt-The Deadliest Mushroom In The Woods
Core-Lokt is offline   Reply With Quote
Old 01-12-2017, 09:00 AM   #3 (permalink)
RonJon '06's Avatar
Ram Year: 2006, 1985
Engine: 5.7, 360
Default
My '06 4wd has a 2500 frame as well. It's extremely tight but like Core-Lokt I was able to unbolt the pickup tube and remove the oil pan without lifting the engine or removing anything from the underside of the truck.
__________________
2006 | 1500 | MCSB | 4x4 | Built 5.7L Hemi
Forged Internals, Edge 2600, HD Trans cooler, JBA Shorties
1985 | W350 | RCLB | 360 | Dana 44/60, Firestone Ride-Rite Airbags
RonJon '06 is offline   Reply With Quote
Old 01-13-2017, 11:15 PM   #4 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
Thanks for this info, I wish I had seen it earlier today when I was working on the truck. I guess I need to turn on notifications
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Plenum gasket Tryin General Discussion 22 05-22-2016 02:31 PM
Replacing the gasket pan...what else should I get done? kissiffer4 Engine & Performance 10 01-02-2014 10:46 PM
oil pan gasket replacement for '98 5.2 Mr. Baseball Tech Info 0 07-18-2013 09:10 PM
98 5.2 plenum gasket$ rwb77w General Discussion 3 06-24-2013 10:03 PM
blown head gasket or plenum gasket? bigred318 Engine & Performance 8 02-26-2012 09:32 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
