lasher10
The other day my check engine light came on and my truck started running rough and lacking power. When I got it home I ran error codes using my Super Paq and got DTC P0307 Misfire Cylinder #7. The fist thing I tried was replacing all the spark plugs. I can't believe what a pain in the A$$ that was. It took me almost 3 hours to change all 16 of those plugs. I have a 2007 Dodge Ram 1500 5.7 Hemi with 40,000 and this was the first plug change on the vehicle. I noticed that the 2 plugs that came from cylinder #7 were much blacker then all the other plugs. The new spark plugs made no difference. Same error code and ran the same. I swapped out the coil pack from cylinder #7 with another one of the coil packs and its still showing misfire on cylinder #7. So I've eliminated any issues with plugs and coils. Any ideas?
