Hello, new member here. I have a 2005 ram 2500 5.7. I had a broken exhaust manifold bolt, last bolt on left side. So I decide to pull the head and remove the bolt. Finally got it out. Put everything back together, all new gaskets, and injector o rings. Torqued everything to spec. Now the truck wont start unless you give it half throttle. Barely runs, wont idle, no way near drivable. I am getting code p0499 now. Took the intake back off to make sure the seals stayed in place, all were good. Gas cap is good. Code just showed up after I pulled the head, fixed one problem , create a bigger one. Any ideas?
