P2096, p2098
jtoscano19
Mcallen, TX
Hey guys I'm new to all this and was coming for some help. My truck has been throwing P2096 and P2098 codes for a while now. What could be the problem? That damn CEL is getting real annoying, Thanks
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
this code can be caused by an exhaust leak, fuel delivery system or oxygen sensor and wiring
Found this too
here is the factory pdf on that code
see below
For a complete wiring diagram Refer to Section 8W.
When Monitored:
With the engine running in closed loop mode, the ambient/battery temperature above (-7°C) 20°F, altitude below 8500 ft.
Set Condition:
If the PCM multiplies short term compensation by long term adaptive as well as a purge fuel multiplier and the result is below a certain value for 30 seconds over two trips, a freeze frame is stored, the MIL illuminates and a trouble code is stored. Two Trip Fault. Three good trips to turn off the MIL.
Possible Causes
EXHAUST LEAK
ENGINE MECHANICAL PROBLEM
1/2 O2 SENSOR
(K141) O2 SENSOR 1/2 SIGNAL CIRCUIT
(K299) O2 1/2 HEATER CONTROL CIRCUIT
(K904) O2 DOWNSTREAM RETURN CIRCUIT
FUEL CONTAMINATION
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING).
Diagnostic Test
1. ACTIVE DTC
NOTE: Check the vehicle repair history. If the 1/2 O2 has been replace make sure that the O2 sensor was properly installed and meets OEM specification.
NOTE: Check for contaminants that may have damaged the O2 Sensor: contaminated fuel, unapproved silicone, oil and coolant.
Ignition on, engine not running.
With a scan tool, read DTCs.
Is the DTC active at this time?
Yes
Go To 2
No
Refer to the INTERMITTENT CONDITION Diagnostic Procedure.
Perform the POWERTRAIN VERIFICATION TEST. (Refer to 9 - ENGINE - STANDARD PROCEDURE)
2. EXHAUST LEAK
Turn the ignition off.
WARNING: To avoid personal injury from the exhaust system being hot, allow the exhaust to cool down to a safe temperature before performing a physical inspection. Failure to follow these instructions can result in personal injury or death.
Visually and Physically inspect for holes, cracks and blockage in the exhaust system.
Is the exhaust system is good condition?
Yes
Go To 3
No
Repair or Replace as necessary.
3. ENGINE MECHANICAL PROBLEM
Check for any of the following conditions/mechanical problems.
AIR INDUCTION SYSTEM - must be free from leaks
ENGINE VACUUM - must be at least 13 inches in neutral
ENGINE VALVE TIMING - must be within specifications
ENGINE COMPRESSION - must be within specifications
ENGINE EXHAUST SYSTEM - must be free of any restrictions or leaks
ENGINE PCV SYSTEM - must flow freely
TORQUE CONVERTER STALL SPEED - must be within specifications
POWER BRAKE BOOSTER - no internal vacuum leaks
FUEL - must be free of contamination
FUEL INJECTOR - plugged or restricted injector; control wire not connected to correct injector
Are there any engine mechanical problems?
Yes
Repair as necessary.
No
Go To 4
4. O2 SENSOR
Disconnect the 1/2 O2 Sensor harness connector.
With the scan tool, monitor the 1/2 O2 Sensor voltage.
The O2 Sensor voltage should read 5.0 volts on the scan tool with the connector disconnected.
Using a jumper wire, jump the (K141) O2 Sensor 1/2 Signal circuit to the (K904) O2 Downstream Return circuit in the O2 Sensor harness connector.
NOTE: The voltage should drop from 5.0 volts to 2.5 volts with the jumper wire in place.
Did the O2 Sensor volts change from 5.0 volts to 2.5 volts?
Yes
Replace the O2 Sensor
No
Go To 5
5. (K141) O2 SENSOR 1/2 SIGNAL CIRCUIT
Remove the jump wire.
Is the voltage above 4.8 volts?
Yes
Go To 6
No
Check the (K141) O2 Sensor 1/2 Signal circuit for an open or short to voltage. Inspect the O2 Sensor connector and the PCM harness connector. If OK, replace and program the Powertrain Control Module per Service Information.
6. (K299) O2 SENSOR 1/2 HEATER CONTROL CIRCUIT
Measure the resistance between ground and the (K299) O2 Sensor 1/2 Heater Control circuit in the O2 Sensor harness connector.
Is the resistance below 5.0 ohms?
Yes
Repair the short to ground in the (K299) O2 Sensor 1/2 Heater Control circuit.
No
Go To 7
7. (K904) O2 DOWNSTREAM RETURN CIRCUIT
Measure the voltage on the (K904) O2 Downstream Return circuit in the O2 Sensor harness connector.
Is the voltage at 2.5 volts?
Yes
Check the fuel system for contaminants.
No
Check the (K904) O2 Downstream Return circuit for a short to ground, open, or short to voltage. Inspect the O2 Sensor connector and the PCM harness connector. If OK, replace and program the Powertrain Control Module per Service Information.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Are you losing any power/MPGs?
Seems like an exhaust leak or the 02 sensors are bad
jtoscano19
jtoscano19
Mcallen, TX
At first I did notice a power loss, but now its back to normal and feels really strong. MPG's actually improved i was at 11mpg now im getting 15.5mpg
jtoscano19
jtoscano19
Mcallen, TX
I went about 1 month without cats, then I put on some magnaflow cats
truckin151
2013 sport
Its the magnaflow cats if thats the case, sometimes they will read them as no cats being there. some non-foulers should probably do the trick.
jtoscano19
jtoscano19
Mcallen, TX
I've heard about doing that non-fouler trick, but I dont know how to do it.
Would a muffler shop do it?
