Have you had any issues at all? Also any cam you recommend? Did you have to get a custom tune done? Also what parts do I need? I have read about upgrading springs and what not?
The only issue I've had has been that its been so damn cold in NJ I can't have much fun cause the roads are snowed over! Haha
I went with the Inertia Crazy Jay Plus after talking with the guys at Inertia. I told them all the mods I had and what else I was planning on doing and they recommended the cam to me. Being that I am a QC I wanted a very torquey low end cam. With my cam I had to get a custom tune but I was planning on doing that anyways so I wasn't worried about that. Inertia also has custom forged pushrods built specifically for the cam you choose to go with so instead of the 6.1L pushrods I went with the custom forged ones. You'll also need the 6.1L exhaust valve springs.
Other stuff you would need is new head gaskets, new timing set, new timing cover gasket, new crank bolt, new cam bolt, a set of head bolts for each side, new oil filter, oil, coolant, ummm...I think that's everything. I'll have to check my email for the parts list later.
You may also need new intake manifold gaskets. I did but I was also fixing a problem I was having so it's not necessary unless you want to.
I think that's all there is. It's a relatively straight forward install if you know what you're doing. If not it may be a bit daunting but its definitely possible. Let me know if you have anymore questions.
