Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Planning a rebuild (over time)
This is a discussion on Planning a rebuild (over time) within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
Originally Posted by RonJon '06 Did some searching and it looks like it bolts to the block on the passenger's ...
Like Tree8Likes
Sponsored By: Moe's Performance
Reply
Old 12-25-2016, 01:21 PM   #31 (permalink)
aheeejd's Avatar
Ram Year: 2003
Engine: 4.7 V8
Default
Originally Posted by RonJon '06 View Post
Did some searching and it looks like it bolts to the block on the passenger's side along with two other wire bundles. Look below the header near the front O2 sensor.
Ok thank you will check it out
Sent from my LG-ls990 using Tapatalk
Sponsored Ad
Register to remove this ad.
aheeejd is offline   Reply With Quote
Old 12-25-2016, 05:32 PM   #32 (permalink)
aheeejd's Avatar
Ram Year: 2003
Engine: 4.7 V8
Default
Yeah the passenger side isn't going to work as it won't reach.
Its stuff like this where again, even if you think its simple & you'll remember, you won't, possibly so take the time to label everything you can. Today just the heater hoses, I was like which one goes where. It held me up, (granted not long) but it shouldn't have. I basically went by how it looked, if I put the lower one up top you can tell it wouldn't look right.
But happy to say, success, engine started. Turned it over without the fuel pump fuse & the fuel pump relay. It actually wanted to run, so I turned key back off. Did this a few times & sure enough I saw life in the oil pressure gauge. Plugged fuse & relay back in & it fired right up. Don't even think I let it run more then a minute cause no coolant hooked up, but wanted to make sure it fired.
Old 12-27-2016, 12:37 AM   #33 (permalink)
aheeejd's Avatar
Ram Year: 2003
Engine: 4.7 V8
Default
Just took it for a ride around the block. At first I started it up & had very high idle & brake light was on & pedal was stiff like frozen. Amazing how things are tied together because I shut it down after I let it get to temperature, & figured out I left the master cylinder breather tube off. The one that goes to the intake, & there is a little nipple next to that. Put nipple on where it goes then break breather & idled beautiful. And brakes are fine.
Need a front end alignment for sure as I changed the steering rack. But it sure feels great to be 99% done. Still have to top off tranny, (need more fluid), bleed out steering pump/rack, & basically put grill on & grill guard (maybe a bit of paint for that. I'll keep on posting here, take some pics of finished product etc.....
Old 12-27-2016, 04:53 PM   #34 (permalink)
aheeejd's Avatar
Ram Year: 2003
Engine: 4.7 V8
Default
Delete
Old 12-31-2016, 11:26 AM   #35 (permalink)
aheeejd's Avatar
Ram Year: 2003
Engine: 4.7 V8
Default
Hauled old engine to be shipped back to Accurate Engines. Truck running great, still haven't put that ground anywhere, I'll figure it out. Have a noise, sounds like its coming from power steering pump, need to figure that out.
Been taking it super easy on engine, not going over 65 MPH, not stomping on it etc.
Old 01-10-2017, 01:11 PM   #36 (permalink)
aheeejd's Avatar
Ram Year: 2003
Engine: 4.7 V8
Default
Well I've got over 1000 miles on the motor. At 511 miles I did 1st oil change & decided to go with Royal Purple. I wanted a Wix oil filter but the store I stopped at (Advanced Auto) did not have any in stock so I went with the K & N filter. Expensive oil change at $70 but hey. I'll look for deals of RP online & whatnot.
Truck is running great. I think I have a short in the wiring that goes to the oil pressure sending unit. Sometimes when I start truck the needle just lays there. Turn truck off, turn back on & presto, right up where its always been. I should have taken the time to clean off the wires & connectors as it is coated in oil from just time, leaks & age. Don't forget, this is an 03, just with a new engine.
And I think I am cursed with power steering pump. The thing leaks from somewhere. With my old motor I was always adding fluid as my steering rack leaked. So when I pulled motor I changed the rack, bought a brand new pump, brand new hoses. And I've got a leak somewhere. Its been to cold here, like 5 to -3 so I'm waiting for 35+ to crawl under & figure this out.
But yeah just wanted to update a little, really running nicely.
Old 05-06-2017, 09:39 AM   #37 (permalink)
aheeejd's Avatar
Ram Year: 2003
Engine: 4.7 V8
Default
Originally Posted by aheeejd View Post
Things are going ok. Great actually because I don't know if it was just late, I was tired or what. But the 2 tranny pan bolts that I thought I stripped out are now tight.
Motor almost ready to start, but I can't for the life of me remember where the long end of the negative battery cable goes. You got the terminal & right on the fender is 1 lead. Then off the other side of the terminal 2 cables come off, 1 is bolted to the frame right near front of tire. The 3rd long one I cant remember, please help someone.
Lol, wasn't sure if I could quote my own post, anyway, I finally figured out where this goes, it bolts on down by the oil trough. I found this out by replacing the trough as I bent old one when removing engine, one of the bolts I could see the groves on it left from the lug on the end of cable. Figured I'd post this & maybe it'll help someone down the road. I know I've gotten lots of help from old threads/posts.
May as well update what's been happening. The issue that I had with oil sending unit, was the sending unit itself, bought another one after I cleaned up wire & connector, used die-electric grease & issue was still happening. So I bought new sensor & now problem is fixed. I was really getting sick of starting truck, needle laying flat, turn truck off, start back up & it would then work. Now works each start.
Oh & the leaking power steering (all new), it ended up being the reservoir. I took pump (pump & reservoir 1 unit) off & took back to O'Reillys & exchanged it for another & now is all good.
And like I said in earlier post, I've chosen to go with Royal Purple & K & N filter. And I just randomly chose to change oil every 7500 miles. Is that way to early & I can go every 10 000 miles? Any opinions on that.
Sent from my Nexus 6P using Tapatalk
Old 07-01-2017, 01:08 AM   #38 (permalink)
Ram Year: 2002
Engine: 4.7L Magnum
Default
Originally Posted by JAMMAN View Post
It might seem like fun, but you are lucky to have 240,000 on a 4.7 without major problems.
I have never completely rebuilt a 4.7, but I've been all over one
From what I have read there are like 3 different sizes of crank journal bearings, and some times the wrong ones can be sold to you even from an experienced dealer or on line shop.
You will need head work which you cannot do yourself, you will need a bunch of special tools like ring compressors and plastic gauges and micrometers to read the plastic gauges.
Not meaning to sound discouraging but a dodge 4.7 is not the motor to start on if you want to practice rebuilding.
But if you are brave and have time plus some money to spend it can be rewarding!
Curiosity... how did you get that many miles on it and retain oil pressure? Did you buy it used and someone had replaced motor parts or?? I have only seen a hand full of 4.7's that run at all close to 200,000. Mine will be one but I did heads and oil pump already. Turned over 177,777 today have pics lol.
My 4.7 is at 215k miles on it and it runs strong like it's brand new. 9nky thing I'm starting to burn a lot of oil on it. I did an oil change last weekend and I got less than 2 quarts out of it but my oil pressure was fine the whole time so I'm guessing it's distributing the oil perfectly throughout the engine. I'll need to constantly check oil level and fill it bit a rebuild is on my list for hopefully the end of the year
Ian_Olivas is offline   Reply With Quote
Old 08-04-2017, 05:45 PM   #39 (permalink)
aheeejd's Avatar
Ram Year: 2003
Engine: 4.7 V8
Default
I didn't burn any oil but I did have issues with oil pressure gauge, I ran hot shots sliction eliminator & i swear that product got me many more miles before engine finally quit.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Time for a rebuild justadodgeman Engine & Performance 14 04-06-2016 02:57 PM
May be time for rebuild justadodgeman Engine & Performance 11 01-18-2016 05:46 AM
Is it time for me to rebuild? Dat_HEMI_Tho Engine & Performance 2 09-16-2014 05:53 PM
2005 rear diff rebuild time chedched General Discussions 12 07-19-2013 09:26 PM
possible rebuild or replace time DA6GSR Engine & Performance 8 11-28-2012 03:58 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
