BigEmpty
- Sep 28, 2017
- 4
- 0
- 2008
- Hemi 5.7L
I have a 2008 Ram 1500 5.7L Hemi, which I've had since brand new. It's been due for a throttle body cleaning as the throttle response hasn't been too great. Today I did its first throttle body cleaning at 75k miles. I removed the neg terminal before removing air intake tube and sensor plugs, then removed the throttle body.
I used CRC cleaner with the throttle body off the truck. Once I removed the buildup (interior side was pretty bad) I put everything back together. Started up instantly with no hesitation and I let it idle. All seemed normal. Once I drove it, I immediately noticed a real delay in throttle response.
Throttle response is just sluggish. Moreso than it was with the dirty TB. Idle rpms stay at around 800, but I see them fluctuate between 1200 and 1000 when driving at city speeds (35-45 mph). The biggest issue is the drop in RPMs when I hit the throttle a little harder, in addition to a drastic drop in MPG reading. I used to idle at and read 10-11 MPG, yet today after the TB cleaning I dropped all the way to 4 mpg.
I'm now wondering if maybe there's something like a gasket out of place, vacuum leak, or if I damaged the TB in some form.
If anyone has any ideas what the issue could be, I'd greatly appreciate your replies.
Sent from my Pixel XL using Tapatalk
