This was originally a different thread about missing rocker arms. I eventually found them all hidden down in the valve springs...2 of the cam shaft bearing caps broke (found those pieces as well) and 1 was cracked.
The original problem reported by the PO was a suspected blown head gasket. I've only got the left head off now, but wanted to share pictures if anyone is able to give any clues about the issue. Mostly it looks good to me except for Cylinder #3...there is some goop pooled on the top of the piston, and some white ash near the edge of the valves (pictures below). Also the head bolt above that cylinder came out with a thick coat of oil.
I figure the head is shot, but I am hoping I don't have an issue with the block. Thoughts?
