Problems problems problems.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Okay. Well. The clamp on the negative side of the battery is extremely rusted, and has broken. My question is is the clamp on the battery welded to the clamp connected to the battery post, or can I buy a new one and just screw everything back on?
ramhunter9
P-Star Jeep Wrangler
Just get a new one that allows two hook up points . I just replaced all 4 in mine . No biggy
good luck
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
So, the wire that goes off to the left in the second picture can be removed easily? Screw off screw on?
ramhunter9
yes , just get a new post . On the negative side that goes to the frame as a ground
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Okay. Awesome. Hopefully this'll be easy then. Thanks.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You will be fine bud, go ahead and pick up some termanal spray while you are there.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Sorry guys. I've been out and about. I don't know what caused it to rust, but it snapped right off. And of course, I can't get it off tonight because of how rusted the bolt is to the clamp. Going to have to go get something to eat away the rust tomorrow morning.
ramhunter9
spray it down with PB Blaster let it sit for a bit and take care of it ... easy fix
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The engine bay looks pretty clean so could but be from alot of washing IDK.
BMRbrnSNRbrd
Norman, OK
2010 Dodge Ram 1500 CC Hemi Sport
You should be ok with any penetrating oil. Just let it sit for a bit.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Yeah. About to go buy some if it doesn't work again this morning.
BlackedOutHemi
BlackedOutHemi
DFW, Texas
2012 & 2012
Thirty minutes of jacking with it with PB blaster an it finally came loose. All good to go.
BMRbrnSNRbrd
Norman, OK
Sucks it took so long but at least it's done!
stevenmicheal
