greatwhite57
Debating on buying either the edge evolution or the superchips cortex. What is you guys opinion on which one I should get. Future mods are mild cam and gear change.
What's the difference between the dsp and the superchips. I really don't plan on goin to wild with it I have it lifted as high as I wanna go. Because its still my daily driver.
I used SC 3865 for awhile but ended up going with a DSP because I plan to do heads cam etc.. If I was going to leave it mostly stock I would stick with SC. Honestly the transmission shifts from SC felt a hell of alot firmer and better than the DSP does. Sc just has the trans shifts down. The truck would lunge forward during shifts and bark the 1-2 and even 2-3 shift. I have 17's. I still get alittle tire spin from 1-2nd with the dsp but not as much and the shifts dont feel nearly as good. The power is there with the DSP but it seems like they are way behind on the trans side...
