Back to the drawing board!!!
I pulled the intake, cleaned it all up, replace all the spark plugs, replaced injector #1, put it all back together and the SAME thing continues to happen. AND IT GOT WORSE!!!!
Not to mention I got a red lighting bolt and loss of power!!!
I have code p0301 still showing up.
UGH SO FRUSTRATING!!
So here is what happened once I started it. It ran rough right of the bat. Threw a low fuel pressure code which cleared itself after I shut it down and started it back up. Initially, it ran rough and it smoothed out and ran great. Good throttle response and plenty of power.
So i let it sit overnight and started it the next afternoon. SAME THING HAPPENED. It started just fine and ran rough just like always. it Immediately threw the P0301 code. and just like always, once it got warmed up, it ran just fine. (I could feel it running a lot smoother now after it warms up, so that was a plus.)
But then something worse happened. I was driving along and the red lightning bolt started flashing and i had no power. If I stepped on the accelerator, it would just bog down. Erratic idle when stopped and even shut off on me. Once it shut off and I started it back on. the lightning bolt was gone and I made it home. I had this lightning bolt pop up before but only for a couple of seconds and then it went away.
So I am back at square one with more problems.
HELP!!!!!
