Drunken Hamster
Turncoat Ford Boi
- Jul 18, 2017
- 1,910
- 357
- South Carolina
- was 2005
- was 5.7 Hemi
Looking to get more out of my truck without making it hopeless in terms of economy. I've got the 5.7 hemi in an 05 with the 5 speed auto and 2wd.
I was wondering if it'd be worth it to convert to a manual when the tranny goes, or swap in an 8-speed and/or a bigger engine{when the engine goes}
I've also contemplated a 4wd/awd conversion for traction since trucks are so light in the rear, and any power adders would only worsen that {turbos and blowers are both quite heavy. And typically in the front}
Looking to retain 12mpg city and about 17-18 highway if possible with 400-600 wheel HP. I also want a true 6-speed or better transmission.
5 seems like the gears are too long to me{not to mention, it's slow to respond to stomping on it because it'll shift twice. In two slow stages. And it has poor response when I only wanna give it a half stomp, probably due to not having enough gears}, and I've read that the 6-speeds just have second gear split or something?? Either way, it sounds kinda bass ackwards to me.
I figured if I swapped the engine AND went with a manual tranny, there would be as few problems as possible. Either way, I just want to know and learn more before I even decide on what path I might take.
