Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Raise rev limit on a 2003
This is a discussion on Raise rev limit on a 2003 within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
Current situation, 392 stroker running custom diably tune from hemifever. Superchips seems to be the only tuner than can raise ...
Sponsored By: Moe's Performance
Reply
Old 08-22-2012, 01:26 PM   #1 (permalink)
Belgiquebasterd's Avatar
Ram Year: 2003
Engine: Inertia 392
Default Raise rev limit on a 2003
Superchips seems to be the only tuner than can raise the rev limit on 03's and apparantly it's possible to stack the superchips and diablo. Has anybody actually done it and how is it done does it matter in wich order you use the tuners and info like that?
On a sidenote, anyone has a superchips tuner they wanna get rid of? Let me know.
Sponsored Ad
Register to remove this ad.
Belgiquebasterd is offline   Reply With Quote
Old 08-22-2012, 01:44 PM   #2 (permalink)
Ram Year: 2004 Dodge Ram
Engine: 5.7L
Default
DSP is for the custom tune only? Yep just read it is.
This is just from experience from my SC/SCT stack.
You will remove the custom tune and return the truck to stock
Plug in Superchips. Setup your tire sizes, shift points and then load the 91 canned tune.
Once done then unplug the SC and then plug in the DSP and load up the custom tune.
Once done you unplug and crank her up
__________________
_-under construction-_
2004 5.7L Dodge Ram RCSB - Sold
TheSatinPumpkin is offline   Reply With Quote
Old 08-22-2012, 02:07 PM   #3 (permalink)
KGBIGCOUNTRY's Avatar
Ram Year: 2004 RCSB/2005 QCSB
Engine: 5.7 / 5.7
Default
*Edit read the question wrong lol
Not sure on the Rev limite on the 03, maybe Greg or Danny can chime in.
__________________
[CENTER]
Got Lope? WANNA GO FAST?
Hit us up at Moe's Performance for all your needs
http://www.moes-performance.com/
KGBIGCOUNTRY is offline   Reply With Quote
Old 08-22-2012, 02:25 PM   #4 (permalink)
Hemi450hp's Avatar
Ram Year: 2011 Ram 1500
Engine: 5.7L Hemi
Default
The only problem with the 03's is that you can raise the rev limiter, but not the shift points. Even with Superchips, you will have to manually shift to see anything over about 5800.
__________________
2011 Ram 1500 - 11.99 @ 110.66MPH N/A
2011 Ram 1500 - 11.09 @ 120.13MPH Nitrous
2014 Ram 1500 - 12.38 @ 109.61MPH N/A
Hemi450hp is offline   Reply With Quote
Old 08-22-2012, 02:58 PM   #5 (permalink)
Engine: 5.7L
Default
When the ratchet shifter and shift light comes to good use.
__________________
Old 08-22-2012, 03:00 PM   #6 (permalink)
Ram Year: 2003
Engine: Inertia 392
Default
Way ahead of ya :-)
I know about all the limitations of the 03 pcm, all I'm interested in is to raise the rev limit, diablo does the rest.
So if I understood correctly, I reset the pcm back to the stock tune using the diablo. Then load the superchips tune (or can I just adjust the rev limit without loading a superchips tune?) and then reload the diablo custom tune?
Thinking about putting the rpm limit @ 6500 rpm (inertia recommendation) what do you guys think?
Since I only want the superchips for the rpm limit one of the older ones (forgot the type number) would be perfect for me, surely someone must have an older one lying around somewhere?
Edit: would a superchips 3715 work, found one for sale and it's considerably cheaper than the more modern ones (wich I don't need)
Old 08-22-2012, 05:59 PM   #7 (permalink)
Hemi450hp's Avatar
Engine: 5.7L Hemi
Default
3715 is the older model for the ram trucks. I was only able to raise my rev limit to 6200 though with the 3715.
__________________
Old 08-22-2012, 06:35 PM   #8 (permalink)
Ram Year: 2003
Engine: Inertia 392
Default
Just found the manual online for the 3715 and it does state that you can up the limit with either 250 or 500 rpm.
Anyone happen to know for sure wich superchips I need to be able to raise the rpm limit to 6500?
Old 08-22-2012, 06:55 PM   #9 (permalink)
Engine: 5.7L
Default
Good Q. Mine (3815 on early 04 TCM) is 6200 when i leave it in D. Custom tune from Sean allows 7k when manually shifting.
__________________
Old 08-22-2012, 07:12 PM   #10 (permalink)
Ram Year: 2003
Engine: Inertia 392
Default
Gettin more complicated -) next question would be can a custom superchips tune be stacked with a custom diablo tune?
Anybody got any first hand experience stacking tuners on a 03, what superchips do I need? Confused now
Reply
Tags
03 ram limiter, 03 rev limiter, ram rev limiter
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2003 Ram parts Hemitom eBay & Craiglist Listings 2 02-15-2012 06:07 PM
2003 level 2wd KeysRam Lifted 6 07-19-2011 10:37 AM
My 2003 RCSB.... CowboyKyle Member Trucks 12 11-23-2010 08:20 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
