Can the pan be taken off an 04 4.7 ho without taking engine out? I wanted to replace rod and main bearings ( oil pump on front with chain ) if this sending unit i replaced today doesn't fix the failing oil pressure drop I have been witnessing on gauge this week. If I rev'd it above 1000 it would come back up.
Has anybody actually done it ? if so what did you learn.... thanks
