Seafoamed 03 Hemi Intake/Gas/Oil... now idles rough
barillms
Did the 1/3 1/3 1/3 Seafoam in Intake, Oil and Gas....
Changed the oil about 50 miles later.
Now.. Instead of running better. It runs WORSE.
it lags and it stumbles and stalls when idling.
What could be wrong?
It ran fine before... I was just doing maintenance.
FlaglerMegacab4x4
Florida
It may be running a little rich from the sea foam you could try clear flood mode and see if that helps.
johnnysart
Albuquerque
5.9 Magnum
Where did you pour the seafoam again?
B
barillms
Youre supposed to put 1/3 in the oil, prior to oil change. 1/3 into the gas tank & 1/3 through the vaccum line that hooks to the brake booster. slowly drizzle it into the line, it sucks it in thru the intake and cleans out gunk.
its gotta be a sensor or the plugs. ill know tomorrow.
i guess this is fairly common after seafoaming...
aperez101
Lodi, CA
My last truck and current truck always stalled out on me for some reason I tried spark plugs before and didn't work it was a sensor the whole time... But then again I'm no mechanic
B
barillms
I did all 16 plugs, the old ones were SHOT. I removed and cleaned the throttle body, and removed and cleaned the PCV valve. I havent run it yet, still putting it back together.
If the new plugs and clean PCV doesn't help... im gonna do the sensors.
Ill post back....
bloombloom88
Plano, Texas
Ill post back....
What sensors? My truck still runs funny between 1 and 2k after I seafoamed
ST-8
I seafoamed my old ford ranger I had, never again will i seafoam a car after how bad the truck ran after.
bloombloom88
Plano, Texas
What's the best thing to use to clean up any sensors that may be gummed up after using seafoam?
After I ran seafoam through my intake, and got it running right again and the CEL went back off, the rpms now float up and down while steady throttle is applied at 30mph, then again at 45-50 at 1700-1800 rpms. It did not do this before
Blackram
I ran seafoam once through my truck, ran like crap afterwards. Will never use that stuff again. It causes more trouble than it is worth.
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
I agree. Watched too many videos on YouTube of bad seafoam results. Not to mention that is is not recommended by the manufacturer to even think about using it.
bloombloom88
Plano, Texas
My truck still runs kinda funny after using sea foam, is there anything I can use to make it run smoother again?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
Might have fouled up your spark plugs. lol
You poor boys and your newer engines. Old school V8's take it just fine. :D
Blackram
With mine I just gave it some time and eventually it started running good again but it took a while.
02Steve15
Connecticut
I guess I have an old school V8 lol
I actually haven't heard of this stuff happening until this thread.
RedFlameRam
