Josh.Larsen
I have a 2005 dodge ram 1500 with the 4.7. I change the oil every 3000-5000 with Mobil golden full synthetic 5/30w and filter. i have a mechanical oil pressure gauge and lately it wants to flutter a lot more than normal. it will do this normally at idle but now it does it when warm. It flutters about 6 psi up and down (so if its at 70psi it will flutter to about 67 and 73), not crazy fast you can still see the needle. not sure why its doing this so any insight helps.
Thanks
Thanks
