They ran the wires from the factory like that for reason , puts less load on the coil driver inside the pcm, do you have a factory pcm? Maybe it turned out not to be an issue with factory pcms.
I doubt it matters. The difference lost to resistance would be so small.
It's more of cleaning up the engine bay
I would not change the designated coil to cylinder combo. If that is what you are saying then yes. I am simply saying shortening wires doesn't change the amount of spark.
