I wasn't sure the best way to word the title. I'm having an issue with my 2007 Ram 4.7L. So far this has happened twice. The first time I was picking up my nephew and had about a 4 hour round trip. I was probably 3/4 into my trip and I started hearing the serpentine belt squeal. It would happen sporadically. Once I started paying attention, I noticed the voltmeter would dip down in the low area of the normal range and then when the belt squealed, it would come back up to normal. It was a wet\sloppy snow so I figured that combined with spray coming up from the vehicle in front of me was causing the belt to get wet, slip, and when it would dry out, everything returned to normal. All my other gauges were normal.
I didn't think much of it until today. I had to pick up my dogs from the kennel and this trip was about an hour and a half. The roads were dry, but we've had warm weather for the last week and all our snow is melting so the air is really damp. I thought it was just doing something similar, but it got progressively worse on the way home. The same thing would happen. Volts would drop. Belt would squeal and it would return to normal. This was the case when I was travelling 60ish mph. Once I got into town and had to drop to 45, the volt meter was staying around the low end of the normal range. I was watching it and it seemed like the longer I drove slower, the more it would drop. I was almost home so I was praying it would make it. By the time I got within a couple miles of my house where the speed limit is 30, the volt meter kept dropping. It was hovering just above L. I shut off my heater blower and my headlights, and then the meter jumped back up to low to mid normal range. After I parked, white steam starting coming out of the engine bay. I popped the hook and there was what I assumed to be water all over the place. The belts and pulleys were wet. The top of the air filter housing, the top of the battery had standing water on it and the wool wrap was wet. Pretty much anywhere that wasn't as hot as the block was wet. To the touch, it seemed like water. But the steam coming out tasted sweet.
I checked the oil and it was filled sufficiently. I checked under the oil fill cap for a white milky substance, but there was none. Although, based on how the oil fill assembly is, I don't know that I'd even see it if it were present. The cap was dry as well as the fill reservoir.
Because I was so focused on the volt meter, I didn't check to see if any of the other gauges were out of range. The part that worries me is that when I was looking around, I could "taste" the steam and it was sweet.
Any ideas or suggestions would be appreciated. I'm by no means a mechanic, but I feel I'm fairly competent and can follow instructions\suggestions.
Thanks,
Joe
Thanks,
Joe
