superchips 3815 kind of disappointing
repsol83
So i bought a flashpaq from a guy on craigslist. (thought it was the 3865) shows up and its the 3815. Either way i install it and put in the 87 octane tune. Guys said they liked the performance gain and the mpg gain so i figured id give it a whirl. I really wanted the speedo adjustment.
So I installed it... is it just me or do these shift points suck? It wants to hold itself in first gear till around 20 mph when driving normally. even if I let off the gas it doesn't want to drop to 2nd.
it used to shift around 2k... now it wants to roll closer to 3k... how is that possibly more fuel efficient?
SILVER_BULLET
thats weird when i had mine installed it didnt do that it actually shifted alot better then stock ....but i was also on the 93 tune so not sure if that makes a difference
HemiBabe
DFW
I have mine on the 93 tune too, did you change your shift points?
I changed mine and I love where they are.
Also, is that the only mod you have on the truck?
R
repsol83
the only shift points I saw that I could adjust were the WOT between 1-2 2-3
Truck is lifted, 35's, K&N intake, Magnaflow Exhaust
SILVER_BULLET
dont know if itll make any difference or not but did you change the tire size to the correct one with the superchips?
R
repsol83
yeah that was the first thing I did...
SILVER_BULLET
hmmm doesent really make sense that it would hold the gear that high just by installing it you got me stumped
R
repsol83
I drive pretty slow out of my subdivision... under 20mph i used to be able to lift the gas a little and it would drop to 2nd and i could putt through the neighborhood. with this installed it holds first the whole time whether i lift or not.
HemiBabe
DFW
Ahhh, yeah mine seems to do the same thing lol
You're right, we can only adjust the WOT with the 3815, haven't had that tuner out in a long time
HLram
Texas
2012 and 2007
Hemi 5.7 in both
Make sure the guy you bought it from didn't adjust the trans tuning (shift schedule). Mine in my 07 has a huge amount of transmission adjustments where I can change every shift up or down etc etc. I got the additional trans tuning when I bought the tuner. Paid extra for it. Was way to much trouble, so I went back to the superchips trans tuning and I don't even use it. I actually think mine is the 3865 though. Plus I run it on 91 tune
SILVER_BULLET
yea the 3815 does not have all those adjustments like yours does for part throttle shifting
R
repsol83
correct... and I thought that was another 40 dollar package to use with the 3865. the guy i bought it from told me it had all that... don't really think he knew what he was talking about
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
If your lifted on 35's your gonna want to run 93 oct with the 93 tune. Also what gears are in the truck currently? That has alot to do with how the truck moves.
R
repsol83
Im assuming the truck has the 3.92.
its a 2005 hemi 1500 big horn.
the truck performs just fine... im not banging her through the gears... just a daily driver and weekend hauler.
whats the advantage of the 93 oct tune and paying more for gas?
I'm not overly concerned with the mileage... just not going to stick premium in a guzzler for no reason..
SILVER_BULLET
my experience was that my truck gave me better milage with the 93 tune loaded on it and also ran alot smoother sure gas was a little more but nothing that broke the bank specially getting a little better milage then the 87
HemiBabe
DFW
+1, same here :)
[Tapatalkin]
ST-8
I had a 3815 before getting a 3865 an you being an 05 sell that thing an get a 3865. The trans tuning really wakes the truck up!
HLram
Texas
2012 and 2007
Hemi 5.7 in both
Mine gets better fuel economy on the hotter tune as well. I have tried them all, even the "mileage" tune and it regularly gets better mileage on the hot one. And MDS turned off too. I did have to pay like $40-50 more for the trans tuning capability on my tuner, too.
ADUBIS
Virginia
3.6 Pentastar
Is all the fuel savings you guys are talking about actually calculated? My overhead console tells me average MPG but I dont have much faith in what its reading.
05daytona
Mine's weird too, I'll check it by hand and compare it to the console and sometimes it's right on other times it's off by a couple mpgs'.
txram956
