Rumblebee
- May 28, 2015
- 14
- 1
- 2004
- 5.7 Hemi
I've seen the flashing lightning bolt a few times since I bought my truck. It usually does it when there's water around, but the last time it did it, I was just pulling out of Burger King. Killing and re-starting the truck has fixed the problem every time.
I hooked my scanner up to it and got a rather strange reading. There are 2 TPS readings and 2 rpm readings. One has a 18 next to it and one has a 10. I've never seen that on any other vehicle I've hooked my scanner to. The scanner says mod 10 is unresponsive and the tps reading with the 10 next to it reads 0.0. Both RPM readings are not the same at all times. They are close so I assume it's my older scanner just being a bit slow. The other thing I find strange is when you floor it, the TPS only reads 86.3%. I once got it to pop up to 93% but it immediately went back to 86.3.
It runs kinda glitchy too. Between having the gas pedal mashed half way down to almost all the way down, it runs very rough. The trans downshifts like it ought to and all, but the truck either surges when it accelerates, or it flat out doesn't accelerate at all until you floor it or let up off the gas till it's less than half way to the floor. Flooring it 100% seems to make it run right, but anything less than all the way to the floor and it screws up.
