Throttle Position Sensor
OklaHemi
new age hemi
so driving home my engine did a jerk and acted like it wouldn't shift down. im thinking oh **** there goes the tranny. the little red light in the lower left corner starts flashing. so i get home and check the manual and read the diagnostic. i get a p2138
throttle/ pedal position
sensor/switch
"D"/"E" voltage correlation
so i looked in my handy dandy chilton and found the throttle sensor on the throttle body, no sweat. im guessing this is a part i can get from either a dealership or advance auto. so my question after all that is there a difference in any? like a upgrade or something. one better than the other? thanks guys
shadow11
Banned
Houston TX
I had to get a new TPS for my old truck and I was able to get it at Auto Zone. I think it was $40
txbass06
NE Texas
5.9 Magnum
I'd stay away from Autozone's electronics if they're still Duralast parts...
shadow11
Banned
Houston TX
Oh and it was $100 at the dealer thats why i went with autozone
OklaHemi
OklaHemi
new age hemi
i like advance auto. i dont know why i just do. ill swing by there tomorrow.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I've replaced my TB and there is no seperate TPS.
This is from the manual:
5.7L V-8
The 5.7L V-8 engine does not use a separate Throttle
Position Sensor (TPS) on the throttle body.
shadow11
Banned
Houston TX
Hey guys, on the 5.7 the TPS is part of the TB.
THROTTLE POSITION SENSOR
DESCRIPTION
The 3-wire Throttle Position Sensor (TPS) is
mounted on the throttle body and is connected to the
throttle blade shaft.
The 5.7L V-8 engine does not use a separate TPS
Time for a TB upgrade.......
I guess thats true cause my old truck was a 4.7 and it was separate from the TB.
truckin151
2013 sport
If you gotta replace it get a fastman ported throttle body. Or i'll sell you my stock tb for $50 shipped, yoours is an 05' right?
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
maybe try to do the TPS recalibration first? before you start spending money? all itll cost you is about 5 min of your time. theres a tut around somewhere on it.
Redtruck-VA
Virginia
It reads something like disconnect the battery for a couple minutes. I touch the cables together. Reconnect the battery and turn ignition on, but do not start for 10 seconds. Turn off then start.
OklaHemi
OklaHemi
new age hemi
i have an 04
i have to replace the throttle body?
dammit man.
ill see if i can find the reset thing
glass3222
Central PA
Try resetting the TPS:
1) Insert ignition key and turn to "ON" (not start).
2) Wait for all idiot lights to go out. Check Engine Light may remain on.
3) Slowly depress the accelerator pedal all the way to the floor.
4) Slowly release the accelerator pedal until it's all the way back up.
5) Turn the ignition key to "OFF".
6) Start the engine.
Redtruck-VA
Virginia
i have an 04
dammit man.
Just look at it as a opportunity to do a upgrade......
OklaHemi
OklaHemi
new age hemi
thanks. im going to take the throttle body out and clean it reall good(if i can reach it, still injured) then ill try this. if it doesnt work ill replace
Redtruck-VA
Virginia
Rus,
Your procedure is for a diesel.....
The 5.7 procedure from the manual is:
(6) If the throttle body has been changed, the following
procedure must be performed:
(a) Disconnect negative battery cable from battery.
Leave cable disconnected for approximately 90
seconds.
(b) Reconnect cable to battery.
(c) Turn ignition switch ON, but do not crank
engine.
(d) Leave ignition switch ON for a minimum of
10 seconds. This will allow PCM to learn throttle
body electrical parameters.
OklaHemi
OklaHemi
new age hemi
i shall do both......
