too good to be true?
kay9
Banned
xxxx
xxxx
Does it do a transmission "Quick Learn" like the STARscan?
BAMA BOY
BAMA BOY
Gasden,Alabama
4.7 Liters of fire breathing fury!
whats a tunerdo really lean it out and mess with timing?
Trupiano
Registered User
6.7L CTD
First off, I can almost promise you if you purchase that thing, it wont work right. A tuner can do a ton of ****. Works on any obdII port, you can look up and clear error codes, tune your vehicle for better performance/mileage, view/record live data from almost any sensor on your vehicle, change tire sizes, top speed, rev limiter, and a ton more, great tool for diagnosing problems, instead of spending an a$$ load at the "stealership." Just food for thought...
