JeffBeck
Hi All,
A few days ago I was starting my truck (2004 Ram 1500, 5.7 Hemi), and my hand slipped off the key after about half a crank. After that it would crank but not even try to start. I finally “pumped” the gas pedal and it started up (I know the throttle is electronic, does not actually pump). It ran fine and got me to work. It threw the following codes:
P0315 Crank Pos Sys Variation Not Learned
P0300 Multiple Cylinder Misfire
P0335 Crankshaft Position Sensor A Circuit Malfunction
It ran okay after that, but now seems to do it more often. It throws the same codes when it happens. Once it starts it runs fine.
The Crankshaft Position Sensor was replaced about a month or so ago, when I was having intermittent stalling issues, along with the Camshaft Position Sensor.
Has anyone had a similar problem? Did you find a solution? Thanks again for all the great information this forum provides!
