Truck Throwing weird codes
Chief115
Hey guys,
I just got a new Actron 9690 code reader. It does it all- trans, srs and abs. Well I scanned the truck and I'm getting weird codes. Not normal P**** codes. Basically, I was hoping someone on here may have had them and has a fix for them, or at least a place I could start looking. Here are the codes--
TCM- 79
SRS- 51 and 59
ABS- 65
I also have P0456. Anyone had that one fixed and it not come back?
And its a 2005 Ram 1500, 5.7
SYKRAMMAN
Banned
Jersey shore
06 Mega
The 0456 is a leak in the evap system. as for the others, get it hooked up to a drb or tech ll, a parts store scanner won't work for those codes, I don't think anyway. How does it run?
C
Chief115
I know the 0456 is a evap code, I was just hoping someone had it and fixed it.
I spent 200 bucks on the scanner I got, and was hoping it would be more useful.
SYKRAMMAN
Banned
Jersey shore
06 Mega
You have to find out where it's leaking, check all the evap hoses and fittings for cracks, dry rot, etc. then go buy some replacement tubing.
