atc06jh
- Feb 23, 2013
- 573
- 320
- Middle Georgia
- 2014
- Hemi 5.7L
So I have a 04 Ram 1500 Hemi and I have a trip to PCB coming up in a few weeks and I want to do a few things to my truck to make sure its running up to par for the whole trip, not that I've had any problems out of it. I bought my truck almost 3 years ago and it had 82,000 on it. Now, it has 134,000. I used to drive it a good bit for work, but now it only gets driven around 300 miles a week. I've never changed the spark plugs or wires, flushed the radiator, or changed the transmission fluid. The only things I've done is change the oil and I had the differential housing gasket and seal changed and fluid redone because it had a slow leak in it at the seal. Are there any suggestions on what I should do to give it a little tune up before the trip? Should I take it somewhere and have them flush the radiator and change the transmission fluid and gasket? Should I buy some new spark plugs and if so, which work best in the Hemi? And on my next oil change, should I switch to a synthetic blend and what filter would be the best? Some people on here say K&N and others MOPAR. I do have a K&N cold air kit on it, but that is all. I plan to get a few things for the exterior for looks, but right now I'm wanting to make sure everything is going to be running good for my trip and just for the overall good care of the truck. Any help and suggestions would be GREATLY appreciated! Thanks in advance!
