Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Engine & Performance
Water pump
This is a discussion on Water pump within the Engine & Performance forums, part of the 3rd Gen : 2002 - 2008 category!
I agree with CostaRam. Since you just had a hose changed recently, that would be the first place to start. ...
Like Tree3Likes
Sponsored By: Moe's Performance
Reply
Old 01-09-2017, 09:42 AM   #11 (permalink)
Ram Year: 2008
Engine: 4.7
Default
I agree with CostaRam. Since you just had a hose changed recently, that would be the first place to start. The leak could very easily be coming from higher up and then trickling down a hose to the bottom of the motor.
Sponsored Ad
Register to remove this ad.
lharrell79 is offline   Reply With Quote
Old 01-09-2017, 02:20 PM   #12 (permalink)
Core-Lokt's Avatar
Ram Year: 2005 Ram 2500 4X4 ST
Engine: 5.7L
Default
Originally Posted by CostaRam View Post
The leak can be also from a corroded fusion opening plug.
I had this happen. I replaced a water pump only to have another leak ~ a year later. I can't prove it, but I suspect it might've been due to having to use "universal" anti-freeze rather than G-05. In small towns, you take what you can get and that's all they had.
__________________
Core-Lokt-The Deadliest Mushroom In The Woods
Core-Lokt is offline   Reply With Quote
Old 01-10-2017, 03:44 AM   #13 (permalink)
Ram Year: 2002
Engine: 4.7L Magnum
Default
Yea im at 204,000 miles on my truck. And i paid 50 for the pump tomorrow after class I'm going to change it out. Any tips on what I need to know? And I also did clean it up and can visibly see the coolant streaks come from the pump. It's very hard to see with everything in the way but once you see it you can tell right away. After tomorrow I gotta find a fit for my other leak lol only bad thing about a older truck. Thank you guys for all the knowledge and help
Ian_Olivas is offline   Reply With Quote
Old 01-10-2017, 03:48 AM   #14 (permalink)
Ram Year: 2002
Engine: 4.7L Magnum
Default
Also what's a fusion opening plug?
Old 01-10-2017, 05:11 AM   #15 (permalink)
usaf2006's Avatar
Ram Year: 2006
Engine: Hemi 5.7
Default
Take your time doing it. Trace the new pump on some card board and as you take bolts off the old one, put them on the cardboard where they're supposed to go. Lots of bolts with different lengths etc. Makes it easier to remember.
I have a picture of what I'm talking about in my build thread linked in my signature.
Blue_Smoke13 likes this.
__________________
2006 1500 RCSB 5.7, 4wd, Paid Off Build Thread
Cosmetic
Debadged Tailgate, New Carpet
Performance
Airaid MIT, SC 87 tune, LT285/70/17 Cooper ATPs
usaf2006 is offline   Reply With Quote
Old 01-10-2017, 06:48 AM   #16 (permalink)
Ram Year: 2011
Engine: 5.7 HEMI
Default
Ian_Olivas,
sorry for the wrong transalation, in english its called a core plug.
https://en.m.wikipedia.org/wiki/Core_plug
Chris
__________________
My worktrucks to haul salty and sand dive gear from the beach
1995 RAM 1500 3.6l single cab 2x4 (rusted away)
1998 Dodge Dakota quadcab 5.2l 4x4 (rusting slowly away)
My 2016 xmas present (self-gifted)
2011 RAM 1500 Sport 5.7l HEMI 35tm (mint)
CostaRam is offline   Reply With Quote
Old 01-10-2017, 08:06 AM   #17 (permalink)
Ram Year: 2002
Engine: 5.7
Default
Freeze plugs
Sent from my VS985 4G using Tapatalk
bulrid8 is offline   Reply With Quote
Old 01-16-2017, 12:19 AM   #18 (permalink)
Ram Year: 2005
Engine: 4.7 Magnum
Default
I'm assuming you've already completed your project. For future reference, the water pump on the 4.7 has a purge valve on the top that will displace coolant if the pump is malfunctioning.
To find out if it is malfunctioning, pressure check your coolant system (you can borrow the tools from AZ or Advance), wait a few minutes, look for coolant on the top of your water pump (about 1-2 o'clock).
I'd replace thermostat, thermostat gasket, and water pump gasket while you've got it off. That's so you don't have to drain the coolant again. It's also recommended you replace the fan clutch because they both have the same service life, and you've got to take the fan assembly off to get to the water pump. (Water Pump should be $45-50, fan clutch is an additional $45-50).
I recently changed out my water pump and got a bad fan clutch from the store. So I'm with a new pump and old fan clutch. Because sometimes you've gota live a little.
smiley3303 likes this.
Blue_Smoke13 is offline   Reply With Quote
Old 01-18-2017, 02:51 AM   #19 (permalink)
Ram Year: 2002
Engine: 4.7L Magnum
Default
Yea I did it the 10th or 11th can't remember exactly but it runs and doesn't leak anymore I just have the damn power steering leak now. And I did not replace the fan clutch I still have the original on but I did replace the serpentine belt because that was original and on rainy days when I drive over a puddle the water would cause the old belt to slip and i temporary lost power steering until it caught back again. It rained today and I drove over puddles and kept my power steering so that's a plus lol
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water leaking/draining water on passenger side.. DatacomGuy Tech Info 8 07-21-2014 12:35 AM
Water? PX8 General Discussions 9 07-16-2013 12:46 PM
water??? 02 Ram Interior 7 05-19-2013 07:17 PM
A Day on the Water h2oman The Great Outdoors 10 06-06-2012 11:50 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
