In my 2014 there is a 110volt 1-2amp? outlet in the front. Is there a way to install a 15-20amp one some on in the truck? Would I need dual alternators for this if so? I'm pretty sure I wont be able to use the current one since the wiring is probably to thin for higher loads, but could one wire one in?
