12v switched power for amplifier on
wykdtr0n
Ecodiesel
I'm at the stage in my audio install where I will probably be turning things on tonight. I'm wondering what the easiest source is for switched power for my 12v amp on in a 2015 RAM?
I know the cigarette lighter is switched, but I'm hoping there's something easier to get to. I've dug around but have only found suggestions for older Rams. Thanks!
PCT
2019 2500 6.4
Northern California
Im guessing your using the stock radio? Have you tried finding out what the switch is for that and tap into it?
W
wykdtr0n
Ecodiesel
I am running the stock radio, despite my utter lack of love for it :)
I haven't had much luck finding wiring charts for the 2015, and I haven't had to rip open the dash yet-I tapped the rear speakers at the door pillars for my signal. I'm also a noob when it comes to a multimeter, but I imagine it can't be much harder than fiberglassing the sub box.
baum
savage, mn
2015 Laramie
there isnt a switched lead at the radio its canbus controlled meaing its digital turn on from the computer.
cig lighter is the easiest and best choice. i personally like to use it only to trigger a relay so it doesnt put any current draw or back feed into the stock circuit.
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
You can grab that switched circuit from a plug under your drivers seat. I forget what color it is but there are only a couple of wires in that plug. Take a meter to it and you will easily find out.
baum
savage, mn
2015 Laramie
that is even worse than tapping into the cig lighter.
vehicles are so sensitive now days that the slightest current draws on existing circuits can fry computers or trip CEL
sbarron
Wasilla, Alaska
Yeah, but power on signal current shouldn't be very much, similar to turning on a relay, no? All power used to function the unit should come from the main power supply?
troutspinner
Gilbertsville, Pa
It is the cig lighter wire.
troutspinner
Gilbertsville, Pa
Right, you are triggering a relay in the amp. Putting a relay in place to trigger another relay is redundant.
W
wykdtr0n
Ecodiesel
Thanks man...I will try to locate that tonight.
baum
savage, mn
2015 Laramie
even on aftermarket radios the remote turn wire is really only meant for 1 amp once you start to add multiple amps its recommended to do it on that situation also.
a relay only takes milliamps to trigger a remote turn on uses more.
sbarron
Wasilla, Alaska
Ah, thanks. I thought it would be milliamps for the remote on as well.
