15 Crew ...advice please
Bamaguy727
I have the 8 inch Nav radio NON alpine....I want to get a better sound , Im not into loud thumping bass ....I have read several ideas on here from putting in a powered sub to replacing speakers ...Is there anything I could do for around 3-400 to improve the sound better or at that price am I wasting money ?
adrianp89
Tampa Bay, FL
The JBL GX speakers would probably be your best bet.
Are you in the Tampa bay area?
B
Bamaguy727
Im over in Alabama , so you would suggest replacing all the speakers with JBL ?
12sportmc
NC
X2 on the JBLs and you can get all of them for under 300 from crutchfield
B
Bamaguy727
I have 4 door speakers and one on dash I think ...what size/model speakers of JBL or Kicker should I buy? Also what's a audio shop charge to install?
sickboy
its a very easy install to do yourself. i went with all Kicker KS series speakers. if you order through Crutchfield, you can't go wrong. they give you all the installation hardware and instruction sheets for your Ram at no additional cost. You should be able to switch out all of your speakers yourself in less than 2 hours. No cutting or running new wires, very few tools.
B
Bamaguy727
would you recommend 6x9s , I looked on Crutchfield there are several different models to choose from ?
baum
savage, mn
2015 Laramie
3-400 is not a huge budget. for that kind of money you are looking at a step just above factory speakers especially if you want to replace the all.
keep in mind that the factory speakers are designed to play with the factory radio nicely. when you change out the speakers only sometimes they sound better and sometimes you may think its actually worse.
IMO even though its good recommendations to ask on here go to stores and listen for yourself. you may find that the recommendations listed above you actually dislike.
Etroze86
Grand Forks ND
Spend 100 bucks of that budget to deaden your doors and then change dash speakers, it will sound pretty darn good after that.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
The 77 KICK speakers will plug right into the factory harness, nothing needed at all.
mcaligiuri
2016 ram 1500 express crew cab
kicker upgrade is well worth the price. highly recommend it.
12sportmc
NC
The JBLs are plug and play as well. They come with an adapter when you order from Crutchfield . I also have the SRAMCQ09 added with mine and it compliments the set up nicely.
deserthi
Diesel
Could someone please give a brief explanation of deadening the doors.
Graygoose
Oklahoma
Convert, for now.
small
A deadening material is used to layer on the metal to stop metal resonating. Helps quite the whole interior from road noises, etc.
makes a vehicle with a better system, or not, sound overall better and quieter and more enjoyable inside.
ehart814
Ecodiesel
Here is my advice:
Order the 3" kicker speakers from Crutchfield for you dash. That little upgrade alone makes a big difference. See how you like that, and go from there. I paid about $50 and it makes a very noticeable difference. It's also very easy to do yourself.
