Hey all,
I have a 2010 Ram, 2500 SLT Big Horn, Crew Cab, Long Bed that I just purchased.
The drivers side window would only move a few inches at a time both up and down. I replaced the Motor (because it went into thermo-nuclear meltdown) and the problem still existed. Eventually I have tracked down a broken pin in the module that sits in the door next to the motor. I think this is most likely my problem.
Is this a dealer only part or can it be found somewhere else? Also, does anyone know exactly what this module is called? Worst case I will extract the pin from the plug and see if i can work my soldering magic.
Thanks all, appreciate any help that can be provided.
Module:
Broken Pin:
Module:
Broken Pin:
