rob.stack1
- Jul 25, 2017
- 50
- 16
- 2014
- Hemi 5.7
I just recently purchased a ram 1500 from a used car dealer. I had an issue with the factory unit where the GPS and Sirius xm would not work. I later found out that my truck was a Canadian built truck and that both the gps and xm will not work in the states. I just purchased and installed a new RA4 unit, after the install the unit said to calibrate the unit by going to a main road with a clear view of the sky. I've done that and still no luck with the map working. Is there anything else I can do to get this to work? I'm not sure if I'll have to replace the antenna or cables. Any help is appreciated.
