Hey guys, in an attempt to make this truck sound good I have spent tons of cash.. Unfortunately, I have failed. I need you guys help PLEASE!!
I wont go into the subs, boxes and amps I have tried because I'd have a book here that I'm sure no one wants to read. I will just list the current items that I have in the truck and why it still sucks.
Hertz 3.5 (all three), Hertz 3 way 6x9s front and rear doors, Hertz one inch tweeters in the headliner. The front door 6x9s were purchased before I knew what I was getting into and I should have just bought a mid diver but oh well. All of this sounds amazing and was a nice upgrade. I had this all on an aftermarket amp but for the sake of being simplistic I took it back to the factory amp and it does a good enough job pushing this equipment.
My problem is with the subwoofers... I currently have two Sundown SA10s in a Fox acoustics box wired to 1 ohm. Sundown recommendations for the enclosure is 1.0 to 1.25cf per sub ported and tuned to 35hz the sub has a .1 displacement. The Fox Box is 1.35 ported to 35hz, So the box fits these subs like a glove!! The amp is a Sundown SCV 2000D so plenty of power.. I have a LC2I hooked up to my factory sub wires for the preouts needed to provide signal to my amp. I have heard this setup in different applications minus the LC2I and in a different vehicle but these things get LOW, DEEP and LOUD!! So as you can imagine I was crazy excited to get this going in my truck..
Disappointment sets in..
My truck sounds nothing like the others I have heard, I mean NOTHING! It cant get low at all, 26HZ is inaudible and the lows from around 32HZ and below lacks in every way imaginable. So I did some research and found a way to test the signal my amp is getting (thanks walledsonic from SMD forum) thinking that Alpine may have put a crossover on the factory sub wires I used to feed the LC2I. What I found made me sick... This thing is crossed over at 31HZ to around 62HZ ALPINE!!
My only option now for a sick sound system is to change this headunit???
I have done a ton of searches to find an adapter or harness to add to my factory HU that will add full signal, I cant find one..
HOW DO YOU BYPASS THIS DSP!!??? How can I get a full range signal capable of 20Hz and up? Is the lowest frequency that this system can provides really only 32Hz???
Please, someone, anyone, HELP!!
