2016 non alpine speaker wiring schematic
mhb1638
Savannah, Georgia
Left Front: GY/VT + GY/YL -
Right Front: DG/VT + DG/YL -
Left Rear: GY/LG + GY/DG -
Right Rear DG/LG + DG/GY -
In Case anybody needs these for aftermarket hookup. Couldn't find anything online, so I went to the dealership.
M
mhb1638
Savannah, Georgia
Can someone confirm the right rear colors? One example shows what I stated above, but beside it in another drawing the colors are reversed order....
Damion
2019 Sport
Your colours are correct
M
mhb1638
Savannah, Georgia
Damien....so The original post is correct? For some reason the dealer diagram reverses the colors on the LEFT REAR (not right sorry). That's why I was confused. So...to confirm....Gray/lg is positive and Gray/dg is negative?
DavidN
Central Florida
For what's it's worth ...
Wiring on my 2013 1500 CC ...
Front Left
+ Dark Green / Yellow
- Dark Green / Light Blue
Front Right
+ Grey / Yellow
- Grey / Light Blue
Rear Left
+ Grey / Light Green
- Grey / Dark Green
Rear Right
+ Dark Green / Grey
- Dark Green / Light Green
Some '13 wiring schematics show
Front Right
+ Grey / Violet
- Grey / Yellow
Damion
2019 Sport
According to my wire diagram for the truck, your first post is correct. It's also the one I used to hook up my line out converter.
M
mhb1638
Savannah, Georgia
Front Left
Front Right
+ Grey / Yellow
- Grey / Light Blue
Rear Left
- Grey / Dark Green
Rear Right
+ Dark Green / Grey
Front Right
+ Grey / Violet
- Grey / Yellow
Your front left and right are reversed from what I have. I'm"told" the diagram is the same from '13 and up
DavidN
Central Florida
Hmm, that's really weird!
I did substantial internet research before I wired up my new door speakers.
If my schematics are in fact wrong I might have hooked up my speakers wrong. Damn it!
Sorry for causing confusion here!
M
mhb1638
Savannah, Georgia
hey if it sounds good....who knows man. I'm just going off what the dealership printed off from dealerconnect. And I researched the internet that 2013 and up are basically the same. But I can't confirm that. The diagram I have is off my VIN.
bucks130
Maryland
Can confirm with Damion that on alldata for my truck (2014, base system) your 1st post is correct wiring.
M
mhb1638
Savannah, Georgia
From this picture, you can see my confusion for the left rear. Glad we got that straightened out!
adrianp89
Tampa Bay, FL
Pins usually go in sequence as well so you could use common sense too. For ex. All positives at the top of the plug, while the negatives are the bottom. Or the plug goes in order across: +,-,+,-, etc. With three other speakers, you should be able to find the sequence.
M
mhb1638
Savannah, Georgia
I'm having a brain fart atm....whats the equipment used at car stereo shops that places a mic in the car and they can tune your amp/system properly?
I ask cause the Kicker amp has DSP. I want to have it tuned properly with all frequencies correct as possible without adding an EQ of course.
NM---found it.....a RTA
bucks130
Maryland
Agreed...very misleading. Did the dealer give you these at the same time? Why is the "shading" for the plug different between the two? Almost looks like they gave you two configurations?
M
mhb1638
Savannah, Georgia
Yes, the dealer-connect printed the entire thing for me. The "shading" goes into a "shaded box" with the words EXCEPT STANDARD CAB. Again, its only different for the left rear. leads me to believe its a type.
BadHabit2Break
Houston, Tx
3.6L
You can download AudioControls app for an ipad or iphone and plug an external mic for this (not the headphones).
M
mhb1638
Savannah, Georgia
The audio control mic is $200 from Amazon. Will any mic work? I can get someone's iPhone. Not sure if any stereo shops do this anymore
