Something you should do first, is check what voltage is going to the LED array (amber LEDS).
Regular bulbs have two filaments, one is bright for turn-sig, the other is less power for parking light…but each filament takes 12 volts.
LED’s are different, they need to have a minimum voltage to turn on, AND you can’t give extra voltage to control brightness …although the brightness does change a little when the voltage changes.
The way you control LED brightness is with PWM (Pulse Width Modulation).
Think of it like this…if you toggle a switch off & on very quickly, you are modulating the power. 50% on & 50% off will equal ½ brightness.
Here is what you need to find out….where is the electronics that actually does this.
They “MIGHT” have the electronics inside the Parking light housing. If they did, there could be a three wire connection (ground, +12 for Park, +12 for turn).
OR…They may just have a 2 wire connection (ground & control) The control would come from an electronics module elsewhere.
If you only have a two wire connection, you won’t be able to get DRL operation with a relay.
Hope this makes sense….let us know what you find.
Could you post your wiring diagram, I would be very interested in seeing it.
Dan
OK, well ya lost me there for a little bit. As for the wiring to the lights themselves...I'm not sure. I'm just using the stock wiring in the back of the headlight harness to tap into. Here's how I wired things so far. (I started a thread on this in the general discussion section also).
I used a regular 12v 5 pin automotive relay.
On the headlight harness -
Pin 4- 12v to that powers the amber LEDs at full, constant power.
Pin 12 - that is the power wire for the turn signal
Pin 2 - Parking light power
From the Relay -
Pin 86 - I ran this to the parking light wire to act as the "off" trigger to test.
Pin 87A - I ran this to pin 4 on the headlight harness to power the ambers at full power.
Pin 30 - I ran this to a fuse on the fuse block that only comes on with the truck.
Pin 85 - Grounded to a reliable ground point.
This is what happened after the above connections were made.
I turned the truck on and the amber LEDs fired up at full power. I activated the parking lights and I could see the smaller side amber light come on in the headlight indicating the parking light function was activated, but the ambers did not dim down to parking light mode as they should have. I could hear the relay clicking as if the connection was closing...but the lights did not dim. So that's where I'm at so far.
I was going to see what the volts were coming from the parking light wire, but I couldn't get the dang harness off the headlight this morning. I got aggravated and have had the truck apart 10 times in the past 4 days..so I'm putting it on hold for a bit. But, if you can give me some advice on if I did something wrong, or you know something else I should do, I'll try it.
