muddog
My 2014 1500 came with integrated tow support (wiring and connections), but no actual tow equipment. I added the receiver(s) (front and rear), and have now also added air springs and a WirelessOne pump. I want to splice the pump into an ignition-on-hot circuit, and have elected to use the Lumision Micro2 Add A Circuit. It seems to me that every location in the PDC has a hot side (battery or ignition) whether or not there is a fuse and wire out to some accessory. Right? So I should be able to plug the Add A Circuit into any correct size empty fuse slot, add my fuse, and wire it up?
