Amp comes on when I open/close doors?? Ignition off - HELP
TNhemi12
Well I got a new amp and it solved some of the problems I was having, but the amp doesn't cutoff like it should. It will go off but come back on with the ignition off. And it can be off and when I open the door, the power comes on. Please tell me what to do. I have drilled a whole in the floorboard and grinded the paint off to connect the ground wire. I'm desperate for help!
TNhemi12
TNhemi12
To my PAC AOEM CHR3, it has a remote wire to connect to.
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
If I don't have an aftermarket radio, I run my remote to a fuse in the fuse box to one that only comes on when the key is on. You might want to try that.
Droid Incredible 2 on the move!!!
TNhemi12
TNhemi12
AND on top of all that, one of my speakers is giving feedback. So either there is something wrong with PAC harness and possibly my RCA cables (well 1 of the 4).
TNhemi12
TNhemi12
Sounds like the pac to me
I definitely think something is screwy with the PAC but I determined this morning that when I listen to satellite radio, the clicking from the 1 speaker goes away but comes back when I play the radio. Could that be a PAC issue or the shielding on 1 of the RCA cables that's near the HU?
quietpeen
2021 TRX
Hellcat
it sounds like the pac is getting the 12v for the remote wire from the wrong place
Rumblebee#2331
Vernon,Ct
sounds like the pac is running off the wrong 12v source, I would call them and tell them, and side note just ordered one yesterday, hope I dont get this too.( nevermind I think my lockpick comes with 12v ignition only power that I can use instead)
TNhemi12
TNhemi12
Frustration got the best of me - never got a response from PAC, pulled off the harness, RCA Cables, and Amp and shipped them all back today. At least next week I will hopefully get my refunds so I can start a new mod....
S
scotts2012ram
Guest
If you need a switch hot aging for a amp I found one today when putting my amp in under the drives seat there are 4 plugs. Get the big gray plug look for the blue wire w/pink strip
chipmaker
AZ
my amp comes on when the door opens also. i don't see it as an issue... was the same w/ my Silverado.
VLG6963
